  #40 (permalink)
Old 07-27-2010, 04:57 PM
patrickt patrickt is online now
Originally Posted by madmaxx View Post
If you go to the Mobil website they indicate their 15W50 synthetic has 1200 ppm of zinc and phosphourous. A little but heavy on viscosity but maybe another option. As far as "old" oil nothing wrong with it as long as the lid is on it. It was in the ground for millions of years, lOL
Perfect example of how someone who does not carefully read your post will get mislead. 15w50 weight oil is exempt from the API limitations on SM oil. So they can indeed have the higher levels of zddp. Now if you pick up that same oil with a different weight, that zddp you want can be significantly reduced. And on the off-chance that oil has the SN rating after October and you see the words "Resource Conserving" on the label, forget it.
