Thread
Solid roller failed again
permalink
07-29-2010, 06:34 AM
bermblaster41
Cobra Make, Engine: Hurricane Motosports
OK [i] am done with the solid roller BULL$$HIT. As some predicted. Not sure of the cause but wiped almost every lobe. Rollers are fine but they ate into my cam. Looking for a simillar cam but hyd roller that will give me approx 550 hp at the crank. My motor is a 408 with afr 205 fully cnc heads, vic jr intake with quick fuel 850dbl pumper. My previous cam had .600 lift with duration around 250s @.050. Looking for any suggestion on experience with other cams. I would prefer an off the shelf cam to speed up down time. I will also be changing out my valve springs and pushrods to match the new hyd cam. Anyone use the MUTHA Thumper cam from comp? Thanks for any advice. Berm
bermblaster41
View Public Profile
Find all posts by bermblaster41
