  #31 (permalink)
Old 07-29-2010, 07:27 AM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
Originally Posted by m5extc View Post
Did you try the rear inner control arm bushings? There is a post on SCOF for this (adding grease fittings). I had the same type of noise on mine, so I removed the bolts, shot lube into the bushing and reinstalled the bolts. The noise went away and has not come back since.
Andrei
Last resort, but have you thought about Andrei's suggestion of adding a grease fitting to the control arms? The other thing you may need to do is pull it apart and grease it.
Doug
