Old 07-29-2010, 07:55 AM
dcdoug's Avatar
dcdoug dcdoug is offline
Originally Posted by twobjshelbys View Post
I was working on mine last weekend and decided I really should get stands. Where do you put them? Anyone got a diagram? I looked while I was under and sort of figured at the end of the tubes, but that does pull them in a ways.
Get the poly covers for the stands and your jack if you don't have it already.
I put the stands on the main frame rails close to the front and rear cross member, unless I am doing something with the oil pan, in which case I put them farther forward on the frame so they aren't in the way.
I find the "stinger" style of stand is very stable. I don't see how the car could slip off with the frame rail cradled properly in the stand.
http://www.summitracing.com/parts/OTC-1772C/
http://www.summitracing.com/parts/PTP-19-1411/
Sears has the same stands.
I also use wheel chocks when I jack it up or if I only have one end on stands. I NEVER leave it just on the floor jack.
www.partskeeper.com
