Have you setup the weight corners yet??
ng8264723 Chris before you waste money on an alignment have the weights setup for the car corners with your butt in the seat. You want the car level and flat with a 49/51 front to back ratio. Also a 1/2 tank of gas in the car. If the car is off the handling will not be upto your expectations. Nothing is worse that a car that doesn't turn and handle for you. Rick L. If the alignment shop doesn't have scales, try and find a dirt track racer and offer him some money to setup your height and weights in the car.
