Yes, paragraph two from the link I posted:
"Before you begin the scaling process you should make sure that the car is race ready. Fluid levels need to be topped off, stagger & tire pressure set, ride heights adjusted, Caster adjusted, Camber set, rear end square and the toe checked. You will also need to take advantage of the maximum left side weight and check to see if your total weight is within the rules and the front to rear balance is where you and your chassis builder want it. Emphasis should be placed on being race ready before you begin the final scaling procedure as all of these factors will have an effect on the end result."
Oh... by the way... I am an authority
