Old 07-31-2010, 02:34 PM
patrickt patrickt is offline
If you have corner scales, now would be the time to look at weight distribution and adjust the chassis as required, because changing it later would change the final camber settings.
That's a quote from this guy, who essentially says the same thing as Dr. Krane, and has written a very detailed PDF on the subject. http://www.scuderiatopolino.com/Susp...20Set%20Up.pdf
