Old 07-31-2010, 02:47 PM
scottj scottj is offline
Cobra Make, Engine: Everett-Morrison, 434 cid
Patrick, I'd don't consider you to be aurguing with me. I posted a link to the Longacre tech article and the article can stand on its own... I wouldn't believe me either. That said, If your make changes to caster and camber you will affect corner weights. That is right out of the Longacre tech article. So yes, the Dr. is dead wrong in his order. But, If you make changes to corner weight while maintaining ride heights, like you are supposed to, alignment will be unaffected.
