  #1175 (permalink)
Old 08-03-2010, 03:03 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Cpt.,
That's the new place? Wow!
Terry, if you look close you can see the outlet of the tank, (Totally different than the stock CR outlet) on the very bottom. Why that leaks is beyond me.
Also because of your ODOR does NOT mean your tank is leaking! The "C.R." vent for the car is pretty antiquated, want to fix it for good, look through my gallery and find the FORD roll over valve* we put in the tank, then pick up a (cheap these days) GM Monte Carlo, Old Camaro, etc., "GAS CANISTER", install it up behind the rear wheel well, run the input line to the roll over valve, the other nipple on the canister goes to "AIR" (also works as a vent!) and your fuel odor should all but disappear!
(Thought I would save you all of the trouble trying to find it.)
*Less than $20.00 from Ford, but you have to remove the tank to install.
Cpt., I'll bet that Stang could tow the Cobra!
Toys, Toys, Toys. Never too many TOYS!
YES, took awhile but the computer finally took the new password, no problems this morning!
