Cooling System Problem - Update...its fixed
I have a stroked 351W in my Superformance. Lately, I the coolant temp ( typically 180 to 210 ) spikes up to 240 and instantly back down
Temp sender is in manifold crossover. Is it possible that the coolant is not flowing ( stuck thermostat ) then flows?
IT has been getting progressively worse now where temp stays at 210 but occassionaly spikes up to 240
Before take out the thermostat housing I want to see if any of you guys have other ideas
Thanks
UPDATE
I replaced the thermostat housing ( and new thermostat with the hole drilled in the top ). Filled it to the top from the sender port and thermostat housing port
I'm suprised how much more coolant the system took. Leads me to believe that there was a hell of a air pocket in there
Strange how the system would over the past 3 months "suck in" air. I think it was from the small leak around the thermostat housing as it cooled
Took it for test drive and temp never got over 190, even in traffic
Thanks everyone for the advise !
