Some of the button clutches are not meant for street use. If your clutch uses really high friction discs, they could wear quickly when used on the street due to the amount of slipping that you have to do to take off from a dead stop all the time.
cobrakiwi makes some good points: pull the inspection plate off the bellhousing and make sure you're not losing any fluid from anywhere and check to make sure you have proper throw out bearing clearance.
www.lykinsmotorsports.com
