Hi guys, I had to do alignment too on my Kirkham, but I think that should become done everytime before your first drive or if you changed hight or anything else...it will be better for your wheels :-)
But did you ever tried to set the caster/camber on your frontend ? That is really difficult...if you ever did it : how did you do that ? I think you need to turn out the screws from the upper a arms in the frame (it's very hard to do if you already installed the aluminium-sidewalls for the motorbay) , adjust the a-arms (turning in or out) and then fasten them again, complete the car with wheels...do the aligment and check caster/camber...if it's not right, do the whole procedure again... :-( Is there any other way to the setting...? I would be happy for every tip :-)
Stephan
