Thread: SPF Bras
Old 08-07-2010, 11:20 AM
madmaxx madmaxx is offline
Neutral
Default SPF Bras
I bought the SPF Bras from Hillbanks. Opened the box and was impressed with the quality. It is thick, It will protect your paint!!! Instructions are not included, but after discussion and surfing the web you bend over the little metal tabs. The top has a pillow that fits in the seam between the hood and front cowling.
It fits tight, tight, thight which is what you want in addition to fitting as perfect as any bras could possible fit, only thing that would fit better is paint. Does it look as good as paint, no, it is a bras, does it protect better than the paint film, no doubt. I have it installed and will see how it wears, i dont drive in the rain, my car is usually 99% spotless so I may not be representative.
To install I recommend the following:
1) Bend all tabs completely over with a tight radius
2) Install on front, getting both side even.
3) Get a buddy and have them hold the hood open while you push back hard to get the pillow in the right spot, it will be obvious and then have him close the hood slowly and let it cook in the sun to stretch a little. Do not get the hood in a bind when closing!!! If you are by yourself then you will have to do the hood force and good luck stretching that thing on. I am sure it can be done.
First on impresson on looks was it looks good nothing compared to paint but in 15 minutes I was like, wow, that makes the car look so much more "race" as opposed a shiny show queen. To be honest it has really grown on me!!!
