Maybe time to quit anyway. The last one started, ran find, turned it off as reported and then everything went Dead! Ok, simple fix, wire was loose on the ignition switch. George got it home started it again, and again, motor (EFI) with an aftermarket PCM system, then started running real rough and I understand it now wont start gain! Bahh - Humbugg!
Kind of makes you doubt yourself, two in a row with some type of problems!
