Old 01-08-2002, 09:43 PM
cobralee cobralee is offline
Default Sway Bars
No matter if its an everyday car or weekend car, I would always recomend sway bars. It doesn't make a difference going straight, but on curves, fast or slow, it prevents leaning, as previously stated. The bigger diameter the better. If you run just one sway bar, make sure its the front, but front and rear are recommended.
I installed the poly urethane bushings which are fine, but on another car, I installed the graphite impregnated ply urethane, which supposedly lessens the squeak. I think it works.
