Thread: Bdr 895
Old 08-08-2010, 08:53 PM
MattM MattM is offline
Kevin - Glad to hear the you enjoying the Backdraft and all is gone well. I greatly appreciate all the nice things you had to say. I have been a member of the form for a while now but usually just read and not post. You can learn a lot that way and usually stay out of trouble. The knobs can be purchased at Summit Racing. http://www.summitracing.com/parts/BSP-26003/ They will need to be drilled out for the heater knobs. The ones at Vintage also look very nice. The Jet Fighter switches can be purchased at http://www.all-neon-car-lights.com/l...et-switch.html You will have to install a relay for the fan switch to make the switch light up properly because the original switch only provides a ground to turn on the fan and the light in the new switch requires positive power to illuminate it. Thanks
Matthew May
http://www.FLPCARS.com
