Old 08-08-2010, 09:19 PM
mickmate's Avatar
mickmate mickmate is offline
Looking good. Holes in the firewall are all components on small ones, bigger ones are for grommets to take tubes and cables. Starting on the passenger side you have starter solenoid, puke tank holes, 2 upper center are tubes to mechanical guages, lower center is wiring harness, lower speedometer cable, upper regulator screws, lower wiring, upper relay, lower fuse panel, drivers side is wiper tube and fresh air cable.
mickmate
http://www.actoncustom.com/
