Originally Posted by Jerry Clayton
The reason for toe in is that friction of the tire on the ground will force the wheel to run in a more straighter line at speed
Yep, what I thought the purpose was as well. If you eliminate rubber bushings from the control arms (get rid of the suspention deflection) then 0 toe would provide lowest rolling resistance at speed.
