Old 01-09-2002, 04:21 AM
cobrajeff's Avatar
cobrajeff cobrajeff is offline
Default You don't HAVE to have a pump
You may not have to resort to a pump to get vacuum for your power brakes. When I put Webers on my Pantera, I made up a vacuum "collector" out of an old fuel log. I ran 1/8" steel lines to each port, and one large line to the connector for the power brakes. I never had any trouble with this set-up.
On my Cobra, I have an automatic trans, so I had to have vacuum for it. I plumbed lines from a couple intake ports to a metal cannister (actually an old "Never-Dull" can) hidden under the car. This is working well, too. For the brakes, I'd pull from all 8 ports, and use a cannister of some kind to store and "balance" the vacuum signal. It'll save weight and money over a pump-type system.
regards,
cobrajeff
CobraJeff
ERA P 202
