  #59 (permalink)
Old 08-10-2010, 05:24 AM
Barry_R Barry_R is offline
Yes that was just an example.
Data by itself is just "numbers" without adequate context.
The material displacement is common failure/wear on solid rollers. Usually shows up on the backside of the lobe as a result of inadequate spring pressure for the lobe profile - or too agressive a profile for the application. The lifter vaults off the top of the lobe and crashes down on the other side.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
