Oil pressure is irrelevant.
Oil pump is positive displacement usually set at 60 psig relief. Regardless if you are at 30 psig
oil pressure at idle or 55 psig flowrate is the same. The heavier the oil the hotter the oil will be. Melling high vome oil pumps are about 3.25 gpm where standard volume is 3 gpm.
