Thread: Cooling Fan
Old 08-10-2010, 03:44 PM
bobcowan's Avatar
bobcowan bobcowan is offline
A lot of this is simple math. A mustang radiater has a surface area of about 351 square inches. A 16" fan covers a surface area of about 201 square inches.
If you simply attach the fan directly to the core with nothing but a gasket, it will only pull air through about 67% of the core.
If you mount the fan to a good shroud, it will pull air through 100% of the core. It will also be slightly more efficient because of the ventouri effect.
