Electric fan wiring.
I've been wanting a Cobra since the sixties. I finally bought a Classic Roadsters 427 SC a few weeks ago. It was supposedly completed in 1991. I love it, but it has a few issues. I had some work done on the distributor and carb. After I got it home I found the fan no longer works as it did before the work was done. It has a thermostat controlled circuit, a manual switch on the dash , and a wire that when attached to the terminal on the fan, makes the fan run all the time. Now it runs all the time, even with a cold engine. Anyone out there have a circuit diagram, or advice? The terminal strip on the left side of the fan has 4 terminals. From top to bottom they are labelled +, G?, M, and C. I'd appreciate any advice.
