barry
you are so right. the wear is on the backside of the lobes, i had taken it for granted that wear would be on the front side. i'll have to look into a better set of springs for the otc afr205s. i guess i might be able to run the cam without a regrind now.
interesting what you said about the
synthetic oil, i had always wondered about that, especially with the flat tappet stuff.
Originally Posted by FUNFER2
lifters are as above, i just checked the rollers and they all look good with no axle play that i could tell. i think they might be on the small side, measuring .8736-.8737. maybe others measure different, but keep that in mind. for the beating the cam took +50 hrs of engine time, they don't look too bad.
