OH Buoy!!
Got the same kit from B&B and also used the same flaring kit you did with success. Get you a piece of sand paper and rough up your surface on your tubing. Clamp it down again and use a wrench to tighten it as tight as you can and be sure to take a small file or something to clean up the inside edge of the tubing you are flaring.
If all else fails go and buy you some AN4 stainless steel braided brakeline tubing with connections(AN4) for about $18.00. If you can't find the braided line where you are let me know and I will send you a some.
Clois Harlan
918-499-4238
"Let's roll"
"Be part of Something Good
