Old 01-09-2002, 08:47 AM
BMMILLER BMMILLER is offline
Default Need Help with Switches
I am in the process of installing padding on my dash. I'm using 1/4" closed cell foam. I currently have three Lucas 2P switches I purchased from Finish Line. The threaded barrel that goes through the dash is only 3/8" long. In order to make these work I will have to compress the foam so much it will distort. Enzo says that Lucas doesn't make a switch with a longer barrel. I like the look of the Lucas switch and would like to stay with that design if possible. Does anyone have any ideas??
Thanks - Blair
