Old 08-12-2010, 05:14 PM
Rick Parker's Avatar
It is a light interference fit. Correct tool is a gear puller but you can do it by grasping the gear from below in a vise, or clam shells and driving the shaft out with a soft hammer or press after removing the shear pin. It is not difficult. Just do it carefully. The squeeze is intended to assist the gear in transmitting the torque to turn the oil pump and not leaving it exclusively to the Shear Pin.
Rick
