Old 08-13-2010, 06:45 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Your engine compartment looks great…Amazing what $1000 can do to dress things up in there....hahahaha
A few things I noticed from your photos…
You only have a single accelerator return spring, and the mounting bracket for the return spring looks to be mounted so that it imparts an angular force on the carb linkage. You might want to correct the bracket and add a second spring.
And unless I’m mistaken, you have what look to be a “JAZ” overflow tank, and it's mounted up-side down. It looks like the drain valve is on the top…Is that the little orange drain valve handle I see in the photo on the top? Unless the tank was modified somehow. I believe they make a recovery/return version of the tank but still looks like it's up-side down. Something to look into.
SPFWiringDiagrams@Comcast.net
