Originally Posted by WardL
As far as functionality, my button won't crank the engine if the trans is in gear even if the clutch is in.
The SPF comes from the factory wired for a transmission neutral switch permissive in the starter circuit. The installer can choose to either connect it to the transmission neutral switch or bypass it. With it bypassed, you're old school.....you can start the car in any gear.
Rodger
