the pan isn't the only factor in the 460 loosing
oil pressure. the 460 is essentially a truck motor designed for a mild hydraulic cam, low rpm usage. when a high lift cam is introduced the oiling holes in the lifter bores get exposed on max lift and full
oil pressure is lost thru the passage resulting in the pan quickly getting sucked dry. extra capacity helps, accusump helps but the source is usually in the lifter galley. when using solid cams in the 460 it is often wise to bore out and bush the lifter bores to eliminate the problem. high lift hydraulic cams also expose the galley. a restricter is often needed.
just my two cents, from wiping out bearings at the dragstrip and finally after two motors finding the problem on the test stand.....
