  #75 (permalink)
Old 08-15-2010, 11:43 AM
cobrarkc's Avatar
cobrarkc cobrarkc is offline
Cobra Make, Engine: Contemporary 482 all aluminum Tunnelport Self built and owned since 1980 frame#0000017 and owner of frame CCX 33961 looking for an FIA body to go with it
Originally Posted by Dazecars View Post
The hubs are interchangable as long as you use newer half shafts so it would be a fairly simple swap. thoughts???
This is not true, the hub shafts are a different diameter so you either have to put a bushing in the wishbone or put different bearings in the hub with a shim around the bearing and a spacer under it to make it work. I just completed this project.
You can use the stock brakes but I upgraded to 12.19" Wilwood That is bracket I made to mount the Wilwoodcaliper in the middle picture along with the bearing, shim and spacer.
Cobrarich
