Thread: Hot air leak
Old 08-17-2010, 10:41 AM
AZ Pete AZ Pete is offline
Cobra Make, Engine: FFR
Sure, Skully, remove the side louvers if they are removable (mine are held on with Velcro for this reason). Otherwise, push the foam pipe insulation in from the front of the footbox. The space gets smaller as you go to the rear so the insulation will compress and hold.
Pete
