Old 08-17-2010, 06:58 PM
wrench87 wrench87 is offline
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
Question efi to carb fuel pump wiring advice?
i am currently running a 342 with mass flo fuel inj and also running a walbro 255 furl pump in my fuel safe fuel cell. i will be converting to a 445 fe stroker and a carb, i have a msd 6al, but i was wondering what the best route to rewire the fuel pump circuit would be?. i was thinking about running a oil pressure switch so the pump would turn on when it sensed oil pressure?. also would it be better to keep the 255 pump and return line and get a different pressure regulator or should i just swap out the pump to a low pressure one and cap or remove the return line?
