08-17-2010, 11:30 PM
AZ
Cobra Make, Engine: SPF2984 MK111, Roush 511 IR FE 8 Stack, Dynoed: [flywheel] 572HP at 6000 , 556# Torque at 4700, Bowler 4R70W Auto Transmision. Tires: Mickey T's S/R 26.0x10.0x15.0 F ,26.0x12.0x15.0 R Color, Bleck, because they told me it was Bleck, at the factory.
Originally Posted by Skully
Thanks for all of the info TinMan.
The problem is the void gets me hot , just want to fill the void. Where in Sun City West do you live? We belong to Briarwood CC, at 135th and Meeker. Oh , getting back to the void, will the foam work, or is that to close to the heat from the engine. The temp on the can says nothing over 240*, the heat coming off the engine is more than that. Do they make a foam designed for more heat?
Skully, Corte Bella, four weeks outa the year, the rest of the time in China, regarding the foam, my understanding is there is a foam available that is used on the shuttle rentry vehicle and the temperatures get red hot depending on the angle of the re-entry. Not sure of the actual temperatures but hot nonetheless, sometimes causing a melt down. I understand Dann55 may work in the aerospace industry and may have knowledge on this, perhaps he may want to weigh in on this topic? Danr55? tin-man
Be well, drive fast, live long
