Old 01-09-2002, 06:03 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Default Front suspension (again)
Been complaining to Darryl at RCC, that this front suspension is still to stiff. Using Heidts tubular uppers, RCC tubular coil over lowers, 375#/in Carerra coil over springs, and Carerra shocks. Using stock MII strut rods and urethane strut rod bushings.
Darryl thinks the springs are about right, the shocks are about right, but if I took the springs & shocks completely out, the front end would still be too stiff because of the urethane strut rod bushings. Makes the strut rod act like an extra spring rather than a locating link.
Put the rubber ones back in? Use something else? What do you guys use?
