I went out for a ride yesterday and started loosing the clutch engagement point. I'm sure it's not the actual clutch but something with the slave cilinder. I only had a minute to check it out last night but the pedal has slop in it at the top and i have be having a problem with finding a minut light
oil leak. I am assuming now that it must be clutch fluid leaking. I can barly see under the fender but have that resivior on the fire wall. I thought that was for the brakes though because it says willwood on the cap. If anyone has had this problem and knows how to fix it i would appreciate it. I was hoping to go to a show this weekend and unfortunatly don't have much time to work on the car. This is the 1st time i have ever had a problem with the car.
