Old 08-19-2010, 05:07 AM
flipscobra flipscobra is offline
Cobra Make, Engine: Superformance aluminum427
Default Leaking Fluid
The clutch master cyclinder is behind the brake MC to get to it you have to take wheel off an you will see a cover in the wheel well take it off an there will be the clutch MC. Make sure you have an Oring on the resavior where it connects to the MC, mine didn't an was sucking air there. If thats okay check your slave cyclinder, since I fixed mine I have not had anymore trouble Good Luck
