Thread: Rear End Leak
Old 08-19-2010, 09:13 AM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
I would definately check your fluid level to start with. It sounds to me like your breather hose is possibly too long. I know that doesnt make sense but hear me out.
Gear lube is thick and heavy. It is also designed to cling things very well....it especialy likes to cling to rubber. Over time with a little mist coming through the hose you could have coated the inside of the hose pretty well with lube. After that happens it only going to amplify any misting during normal breathing of the rear end. A shorter, larger diameter hose might help.
how is the baffle set up? If it is set up in a way that it will cathc and hold any lube at all your going to have a problem. There is a severe amount of lube being thrown around in there while your driving you would be surprised where it can go and get caught.
Just my thoughts.
Gene
" If it wont break em loose in 3rd gear, it aint enough power "
