Originally Posted by patrickt
But I think I can make them invisible to the eye when you are not touching your brakes -- maybe by even dropping down to the 3mm. Would you still they were unattractive if you could not see them when they were not lit?
EDIT -- now mind you that each of those little clear domes would be only 3mm in diameter and peek out less that 1mm!!
If you can't see it, then it would look fine when not lit, and probably odd, but safer when you hit the brakes.
Possibly it could look cool when you hit the brakes, but I'm skeptical. Happy for you to show us though!
It would give RodKnock another reason to use his raceramps.
www.partskeeper.com
