So with balancing the clutch and flywheel together did that halp any? Or are you still working on putting back together?
Nevermind...went back and read your previous post about balanced and put back.
Run a compression test and drop the pan...it might tell you something might not..but at least you can eliminate that.
" If it wont break em loose in 3rd gear, it aint enough power "
