It is a custom bracket that Nick Acton made up to use the tanks on the Windsor blocks. The local shop that he used to have work on the tanks did a horrible job restoring them. The tank had developed a pin hole leak while I was in NH, and we patched it, but it obviously did not hold....Nick thinks the tank needs to be taken completely apart, cleaned, and the joint re-soldered.
"Freedom is only an illusion when the government has all the guns."
