Mohuska,
I'm very unfamiliar with a West Coast set up / suspension.
My first thought is how it was lowered? Did they just cut the springs? If so...bad, very bad. Did they use Drop Spindles? It sounds reasonable that you may just have to start over and get the proper suspension. It all depends on what you expect to do with the car.
Does the WC Cobra use the MII suspension type set up? What's on the rear?
I'm sure with guys on here like Jack, Don, and many others, we can turn that baby into a real asphalt burnin', tire squealin' autocross butt kicker!
Give us some absolute full details. Engine, type suspension front and rear, Ind. or straight axle? Weight, and ratio's if you know them.
This is what this board is all about, I do love it so!
DV
