In addition to your valve notches not being at the proper location for your Edelbrock heads with the size valves you have----the absence of any carbon build up on the remainder of the piston top indicates that you probably don't have enough clearance in the squish area--either the pistons are above the deck or your gaskets are thinner than .047 compressed. Or possibly some pretty severe reversion/scavaging
