Old 08-23-2010, 03:52 AM
boris_thespider's Avatar
boris_thespider boris_thespider is offline
Cobra Make, Engine: B&B, 1969 392w, Tremec TKO
Default Brake caliper issues
I'm having problems with my rear brake calipers leaking fluid at the banjo bolt. I've tried everything that has been suggested to fix the problem (new hose, new banjo bolt, new copper washers, tightening it more, cleaning the surfaces... etc, etc). Is there anything else to try? I'm getting sick of it. I'm looking to replace the calipers with a set that won't break the bank. I believe the calipers I have are GM (came with my kit). Are there any GM replacement calipers that you've had good luck with that will work with the original B&B 9" setup? Thanks...
Mike
