Old 08-23-2010, 06:44 PM
sevenohms sevenohms is offline
Cobra Make, Engine: Venom, BF XR8 260kw, 6 speed auto
Originally Posted by letsboogie351 View Post
Nathan I hope this helps. You cannot see anything from above the engine. It is too much trouble to pull out the inner guards to take pics so I have some from during the build. The headers sit close to the block. You will notice a triangular section in the chasis just in front of the footboxes. This is where the exhaust exits to go either under the car or through the front guards
Doug
Looks good.. what is the dimension you are using for the width of the outer rails (that go under the doors)?? Mine is about 1300mm.
