redmt....first off set a budget and stick as close to that budget as you can ( the little stuff adds up the fastest ).....if you are going to use it for daily transportation then consider keeping your project AS SIMPLE AS POSSIBLE..a mild small block and 5 speed will scare the water out of most anybody you take for a ride...a mild big block (FE) will do even better.....do your home work and ask a lot of questions.....and theres nothing like being able to say "I built it in my garage"....
