Old 08-25-2010, 05:43 PM
NZCOBRA NZCOBRA is offline
Cobra Make, Engine: Berry Cobra ,Tremec 5 spd . 408 windsor , double A arm 9"rear
Hi, an uneven thickness will cause this ,if they were second hand rotors and had hard spots ,when you machine rotors these hard spots will push the carbide tool away, and need to be ground after-wards , or put new rotors on , run them in follow instructions on rotor box. . slight rotor run-out is ok . this will keep pads back.
