08-26-2010, 06:36 AM
KY
You could use a Ford 460 stroker piston if you're really in a bind.
Use a standard 4.360" bore, or a .030" over 4.390" bore.
FE deck height = 10.170 - 6.700 rod - 2.125 (1/2 stroke) = ~1.345" C/H
If you used a 557 piston with a ~1.350" C/H, it would share the same wrist pin as the BBC rod used in the FE strokers.
