  #251 (permalink)
Old 08-28-2010, 12:37 PM
*13*'s Avatar
*13* *13* is offline
The Fuel log is a great addition. Looks super cool! Two Things I experienced with mine, FYI.
#1 it cooked the fuel the first run. I had to slot the uprights which lowered the heat transfer to the fuel manifold.
#2 Keep the hoses as low as you can. Mine vapor locked on me, took me a while to figure it out. I filled the bowls up with fuel after I shortened the hoses a bit (which took some of the arc out of them). Haven't had the problem since.
Hyde
Originally Posted by jeffy View Post
After talking things over with Doug, Peter P. and Jim Inglese, we decided to swap out the single piece fuel harness for "octopus" fuel lines as were used in the original comp cars. Jim already has a fuel block fabricated and will have it installed this week. Below is CSX 2558:
The fuel block sitting on the dual water outlet y-pipe:
ERA FIA 2088
