Old 08-28-2010, 01:17 PM
Jim Kellogg's Avatar
Jim Kellogg Jim Kellogg is offline
Cobra Make, Engine: Superformance MKIII #887, drive it a lot!
Send a message via Yahoo to Jim Kellogg
Check the negative battery to ground cable for a good connection. Try pulling on both ends of the negative battery cable at the battery box. I once found a bad connection at the negative battery cable to frame on 887. Lost all power, but fortunately was only one block from home!
I pulled the negative cable, and made a new end for the battery to frame connection.
Give it a try, and let us know how you make out with it.
Jim Kellogg
Elmira, NY
